How to Unlock the Evolving World Car Meet Challenge in Forza Horizon 6
BlazeTiger
#1 Сообщение BlazeTiger »
The “Evolving World Car Meet” challenge in Forza Horizon 6 is one of those activities that sounds more complicated than it actually is. A lot of players assume there’s a hidden progression requirement or some kind of unlock condition tied to Festival levels, but in reality, the feature is already available from the start of the relevant playlist content. You don’t need to grind anything special to access it.
This challenge is part of the Horizon Decades Festival Playlist content, and the Car Meet location is simply placed on the map as a seasonal activity point. Once you know where to go and what car to use, completing it takes only a few minutes.
Where to Find the Evolving World Car Meet
The Car Meet location appears on the eastern coastline of the Hokubu region. It is positioned just north of the Irabuohashi Bridge landmark and sits right beside the Hokubu Time Attack circuit on its eastern side.
If your map looks crowded or cluttered with icons, the easiest way to spot it is to adjust your filters. Turn off everything except Car Meets. This removes most distractions and makes the event marker stand out immediately.
The area itself is fairly open, so once you’re nearby, you’ll usually see parked cars and a designated meetup space rather than a traditional race start line.
What You Actually Need to Unlock It
There is no separate unlock process. The Car Meet is already active as part of the seasonal playlist. The only requirement comes from the daily challenge tied to it, often labeled something like “Sweet Car O’ Mine.”
That challenge simply asks you to attend the meet using a specific type of vehicle and park correctly in the designated area.
How to Complete the Challenge Step by Step
The completion process is straightforward once you understand the requirements:
First, switch to an eligible vehicle. The challenge typically requires a car from the 1980s. You can filter your garage by year and select any suitable model. Starter cars from that era work fine, and so do many barn finds if you’ve collected them.
Next, drive or fast travel to the Car Meet location in Hokubu. The trip itself is usually short if you’re already in the eastern region of the map.
Once you arrive, look for the marked parking spaces. These are clearly separated from normal driving lanes, so you won’t miss them unless you rush through the area.
Finally, park your car in one of the designated spots and confirm the on-screen prompt to join the meet. As soon as the game registers your entry, the challenge completes instantly.
You’ll receive your reward right away, usually including credits and a Festival Playlist point, which contributes toward your seasonal progression.
Tips to Make It Faster
A common mistake is arriving in the wrong type of car and having to back out to switch vehicles. It saves time to set your garage filter to 1980s cars before you even fast travel.
Another useful trick is to clear your map view before heading there. With fewer icons visible, it’s much easier to navigate directly to the correct coastal section without overshooting it.
If the parking spaces look occupied or unclear, just circle the area once. The game usually frees up a slot quickly, and the prompt appears as soon as you position your car correctly.
The Evolving World Car Meet in Forza Horizon 6 is designed more as a social checkpoint than a traditional challenge. There’s no hidden requirement or progression gate behind it. Once you know the location and bring the right type of car, the task becomes a quick stop rather than a full gameplay session.
It’s one of those seasonal objectives that rewards simple participation—drive in, park, and move on to the next activity.
