MMOEXP ARC Raiders: How to Unlock the Spaceport Hidden Bunker and Farm Rare Blueprints
suhanidash557
#1 Сообщение suhanidash557 »
This guide breaks down the full process of unlocking the Hidden Bunker in the Spaceport map of ARC Raiders. This hidden event is one of the most rewarding activities in the game, offering high-tier loot, rare crafting blueprints, and progression-critical data objectives. For players looking to accelerate their progress, some may choose to buy ARC Raiders Items to complement their in-game efforts, but understanding the mechanics and execution strategy is essential if you want to consistently secure these rewards through gameplay alone.
Locating and Activating the Antenna Arrays
The bunker event begins with four Antenna Arrays scattered across the Spaceport map. Each antenna is positioned on top of a structure, requiring players to climb to the rooftop to access the activation console. These consoles are the key interaction points that initiate the event.
Once you locate an antenna, you must manually activate it. This action triggers a defense phase where the system attempts to disrupt the signal. It’s important to stay alert, as activating an antenna immediately puts you into combat.
Defending Against Drone Waves
Each antenna activation summons two waves of hostile drones, commonly referred to as “Wasps” and “Hornets.” These enemies are fast, aggressive, and capable of overwhelming unprepared players.
To survive, positioning is critical. Natural cover—especially rock formations—is highly effective for breaking enemy line of sight and reducing incoming damage. Players should avoid open areas and instead use terrain to control engagements. Managing ammo and maintaining awareness of drone spawn angles will significantly improve your chances of success.
After successfully clearing both waves, the system will confirm completion with an on-screen message indicating that the antenna has been activated. This process must be repeated for all four antennas across the map.
Unlocking the Hidden Bunker
Once all four antennas are activated, the Hidden Bunker will unlock. The bunker has three separate entrances, all marked on the map once the event is completed. Players can choose the most accessible or least contested entry point depending on the situation.
However, reaching the bunker is not risk-free. Since this is a high-value event, other players are often drawn to the area, creating potential PvP encounters. Timing your movement and staying cautious during approach is just as important as completing the antenna phase.
Loot, Blueprints, and Data Objectives
The Hidden Bunker is one of the most lucrative locations in the Spaceport. Inside, players will find a large number of loot containers, significantly increasing the chances of obtaining rare items.
One of the most valuable rewards is the “Volcano Blueprint,” a high-rarity crafting item used to create powerful gear. While this blueprint can occasionally drop from containers elsewhere on the map, the drop rate inside the bunker is noticeably higher due to its status as a special event zone.
In addition to loot, the bunker is also a key location for completing data download objectives tied to certain missions. This makes it not only a farming hotspot but also an essential area for progression.
Solo Difficulty and Efficiency Considerations
For solo players, the bunker event presents a moderate challenge. The main difficulty lies in surviving the drone defense phases while remaining aware of potential third-party players. With proper preparation—adequate ammunition, smart positioning, and efficient target prioritization—solo completion is entirely feasible.
The reason the bunker is considered the most efficient place to farm blueprints comes down to probability. Unlike standard areas, event zones like the bunker feature boosted loot tables, making high-value drops more consistent over time.
Final Thoughts
Mastering the Spaceport Hidden Bunker event is a major step toward optimizing your progression in ARC Raiders. By efficiently activating antennas, surviving drone waves, and navigating the risks of player interference with ARC Raiders buy BluePrints, you can consistently secure some of the best rewards the game has to offer, while some players may also look into cheap ARC Raiders Items as a supplementary way to enhance their loadouts and overall efficiency.
