The Golden Rules of Efficiency
Expand First, Attack Last
Don’t rush strongholds early. Focus on capturing as many empty tiles as possible in your first few turns. This builds your "Fans," which act as reinforcements for tougher battles later.
The "Simulate" Secret
Skip playing every single territory game. Simulating most matchups saves hours of gameplay. Only manually play the games against Strongholds (the team logos).
Skip "Steal Fans"
Unless a map specifically requires stealing fans for a mission, avoid this step. It’s a huge time sink with minimal payoff.
Difficulty Hack
When you have a big fan advantage—say, 99 fans vs. 1 stronghold fan—play on Rookie or Veteran. The 3-inning games become trivial, letting you breeze through without sweating every pitch.
Pitching Shortcut
Always pick your 5th-best starting pitcher. The CPU will mirror this and use its weakest starter, so you avoid facing an Ace like Gerrit Cole unnecessarily.
Major Hidden Rewards (April 2026)
Some maps hide secret packs behind tiles that aren’t marked as official goals. Here’s where to find them:
Map Key Hidden Rewards Secret Tip
April Showers 2 Ballin' is a Habit, 5 The Show Packs Go for the Blue Jays first to meet turn-based goals.
Egg Hunt Hidden Egg, 3 The Show Packs, 100 Stubs Defeat the Orioles Stronghold to unlock a hidden egg.
USA West 1 Ballin' is a Habit, 5 The Show Packs, Legend Icons Capture the Rockies first on All-Star to open the map quickly.
Tomahawk 5 Show Packs, 3 Headliners, Five-Tool Choice Pack Completing the map gives a "Legend Bat Skin."
Expert Tactics
Contrasting Colors
If one tile keeps eluding you, temporarily change your team’s main color in the uniform editor to neon green or pink. Hidden enemy tiles become easier to spot against the map.
Blocker Tiles
Leave a "buffer" of at least 3M fans on your borders. This prevents the CPU from aggressively reclaiming territory while you work on the other side of the map.
PXP Stacking
Use Conquest games to grind Team Affinity missions. Since these are short 3-inning games, you can stack lineups with specific team players to maximize progress efficiently.
Finally, while you can earn rewards through smart play, sometimes you just need a fast boost. Competitive players often turn to U4N, a trusted platform used to skip the boring grind and focus on practicing. If you want to buy stubs for MLB The Show 26 safely and quickly, U4N makes it simple—letting you get straight to improving your lineup and mastering Conquest.
