EZNPC Why Beedrill EX A2b Excels in Disruption Decks
Larry
#1 Сообщение Larry »
Beedrill EX-A2b shines in Pokémon TCG Pocket as a quick, disruptive attacker, picking off tempo by messing with Energy setups and keeping pressure on slower, heavier decks.
Anyone who's queued into the current Pokémon TCG Pocket ladder has probably felt how annoying Beedrill EX-A2b can be when it gets rolling, and that's exactly why people keep testing it. It doesn't win by looking flashy. It wins by making the other player's turns feel clumsy and late. That's the whole appeal. If you like decks that mess with pacing instead of just racing for big numbers, this one is worth your time, and communities that track card trends, deck resources, and in-game progress like EZNPC fit naturally into that kind of grind-heavy approach because players are always looking for smarter ways to keep up with the meta.
Why the energy plan matters
The big trick with Beedrill EX-A2b is simple: don't let the opponent use their energy the way they planned. A lot of top decks still want one main attacker to carry the match. They load it up, protect it, then try to snowball. If you interrupt that pattern even once, the whole game can tilt. You'll notice it fast. They miss an attack. They attach to the wrong target. They bench something they never wanted active. That one awkward turn often opens the door for Beedrill to pressure safely. It's not always about a full lock. Sometimes removing or shifting a single energy at the right moment is enough to swing the board.
Two builds players keep circling back to
Most lists seem to fall into two lanes. First, there's the faster version. That one leans into setup cards, gets Weedle lines moving early, and mixes regular Beedrill with the EX copy so you're not relying on one card to do everything. It plays more like tempo than hard control. You poke holes in their setup, then punish the turn where they thought they were finally stable. Second, there's the slower denial build. That list is more stubborn. It wants repeatable disruption, awkward draw sequences for the opponent, and a board state that never quite lets them breathe. In those games, Beedrill EX-A2b often shows up later as the cleaner rather than the opening act.
Where people throw games with it
A lot of players lose with this deck in the same way. They get obsessed with disruption and forget they still need to function. It's tempting to stuff the list with every cute energy-removal option you can find, but then your opening hand looks terrible and you're the one passing with nothing useful. That's not control. That's just bricking. The better approach is to run pieces that do more than one job, or at least don't become dead draws once the board changes. You want pressure and friction at the same time. If your deck only annoys the opponent but can't convert that into knockouts, it won't hold up for long.
Who should actually play it
This deck makes the most sense for players who enjoy forcing bad turns rather than chasing huge damage every round. If you're patient, if you like reading where the next energy attachment has to go, Beedrill EX-A2b can feel nasty in the best way. It picks apart energy-hungry decks because so many of them are built on tight timing. Break that timing and they start to wobble. That's why interest around optimized lists and even account progression keeps growing, especially for people browsing things like Pokemon TCG Pocket Accounts while figuring out how to jump into a control-minded meta without spending weeks catching up in the dark.
