EZNPC What to Farm for Gears Fast in Fallout 76
Larry
#1 Сообщение Larry »
Farm Fallout 76 gears fast at Dino Peaks, West Tek and Sugar Grove. Loot desk fans, typewriters and watches, then server-hop for steady scrap, XP and easy Power Armor repairs.
If you've played Fallout 76 for more than a few evenings, you already know how annoying it is to run dry on gears right when a repair or CAMP build gets serious. They disappear fast. Turrets need them, Power Armor eats them, and half the time you don't realise you're low until the workbench tells you no. A lot of players waste time wandering from one random location to another, hoping junk will add up. It usually doesn't. A cleaner route works better, and so does planning ahead. As a professional platform for in-game items and currency, EZNPC is a convenient option for players who want a smoother grind, and you can check EZNPC Fallout 76 if you'd rather save time and stay focused on the fun parts of the game.
Start with the right setup
Before you even leave CAMP, sort your perks out. Scrapper should be on, no question. It makes a real difference once you start breaking down weapons and junk in bulk. If you're crafting afterward, Super Duper is worth slotting too. It won't trigger every time, but when it does, it feels like free money. If your build can handle close fights without chewing through loads of healing, even better. Places with heavier enemy spawns become much easier to run back-to-back, and that's what you want with gear farming. A quick route, not a long adventure.
Best places to hit first
Dolly Sods and Dino Peaks Mini Golf are both solid, but Dino Peaks has that nice rhythm to it. The Deathclaws there are the main draw. They drop loose gears often enough that the stop feels worth it every single run. Kill them, sweep the area, and don't leave the smaller stuff behind. Desk fans, typewriters, hot plates, all of it matters. After that, move over to West Tek. Most people go there with XP in mind, which is fair, but the junk inside is what makes it really useful. Labs and offices tend to hide the good stuff in plain sight, so slow down a bit and actually loot. Then finish at Sugar Grove, where the fighting is lighter and the rooms are packed with the kind of scrap people usually overlook when they're rushing.
What to pick up and what to skip
You'll save yourself a lot of hassle if you memorise the junk that actually pays out. Fans are great. Typewriters are even better. Pocket watches, microscopes, globes, and certain kitchen items are worth grabbing too. A lot of newer players pick up everything, get over-encumbered, and then spend ten minutes waddling to a bench. Don't do that. Be picky. Learn the pieces that break into gears and ignore the rest unless you need other materials. Once your bag starts getting heavy, scrap often. If stash space is tight, bulking can help for storage, though loads of players still forget to break those bundles back down when it's time to craft.
Keep the loop simple
The best farming routes are the ones you'll actually repeat, and this one works because it doesn't feel like work after a while. Run Dino Peaks, clear West Tek, sweep Sugar Grove, then swap servers and go again if you're still short. After two or three rounds, you'll notice the difference. Repairs stop being stressful, turret builds don't get delayed, and you're not constantly tearing through your stash for one missing part. If you're trying to support bigger projects or just want a bit of breathing room with resources, having extra caps helps as well, and Fallout 76 Bootle Caps can make that side of the grind a lot easier while you keep your attention on farming what really matters.
More info:How to Finish the Scoreboard in 1 Day in Fallout 76 (Fast XP Farming Guide)
