EZNPC How to Use May B1 268 in Pokemon TCG Pocket
Larry
#1 Сообщение Larry »
May B1#268 is a handy Pokémon TCG Pocket Supporter that helps evolution decks find key Pokémon, fix clunky hands, and stay consistent through the mid to late game.
Anyone who's spent time in Mega Rising knows how awkward evolution hands can get. You draw the wrong Basic, miss the middle piece, and suddenly the whole turn feels wasted. That's why May B1#268 has become such a handy Supporter in real matches. As a professional platform for buying game currency or items, EZNPC has built a solid reputation for convenience, and if you want to improve your collection experience, EZNPC Pokemon TCG Pocket is a practical place to start. The card itself isn't about raw power. It's about fixing bad hands before they cost you the game. May lets you take two random Pokémon from your deck, then for each one, you shuffle a Pokémon from your hand back in. So no, you're not going up on cards. But you are cleaning up your options, and that matters a lot more than it looks.
Why the effect feels better than it reads
At first glance, May can seem underwhelming. A lot of players look at the text and think, "Why bother if I'm not gaining anything?" But once you actually use her, it clicks. She's not there to draw more. She's there to turn dead pieces into live ones. If your hand is clogged with extra Basics, or stuff you needed two turns ago, May gives you a way out. You toss back what isn't helping and take another shot at finding the evolution piece that matters now. In decks built around Stage 2 lines or Mega Evolution ex cards, that kind of filtering can be the difference between stabilising and completely stalling out.
Where she fits best
May isn't a card for every list, and that's fine. If your deck is mostly fast Basics and you're trying to pressure from turn one, she's probably too slow and too narrow. But in slower builds that need exact pieces, she earns her slot. You'll notice it most in decks that can't afford to sit with the wrong Pokémon in hand. She also gets better when paired with other forms of deck thinning. The fewer wasted targets left in your deck, the better your odds of turning her effect into something useful. Timing matters too. Since Supporters are once per turn, most players get the most value by holding her until the turn before a key evolution or a swing turn where the board has to come together.
Pull rates and crafting value
Getting this exact version of May isn't always straightforward. She's a 2-Star Supporter from the Mega Blaziken side of Mega Rising, which puts her in that awkward middle space. Not impossible to find, but definitely not common either. Most players won't see her often in the early pack slots, and the better odds tend to sit later in the pack, which still means luck plays a big part. That's why crafting starts to make sense if you already know she fits your deck. The cost is 1,250 Pack Points, and those points need to come from Mega Rising packs specifically. It's a steep ask, sure, but for players building around consistent evolution chains, it can be worth every point.
A quiet card that wins turns
What makes May good isn't flash. She's not the kind of Supporter that creates huge highlights or makes the opponent instantly panic. What she does is much subtler. She reduces the number of turns where your hand just doesn't work. That's a big deal in a format where one bad setup can snowball fast. If your deck needs exact Pokémon at exact moments, she's one of those cards you start appreciating more the longer you play. A lot of players chase obvious threats, but smart consistency pieces often do more over a full run, and that's exactly why serious collectors keep an eye on Pokemon TCG Pocket Cards when they're planning upgrades for evolution-heavy builds.
More info:Pokémon TCG Pocket New B2 Set Teaser Explained – Mega Evolution Hints & Is the Deluxe Pack Worth It?
