EZNPC Guide How to Farm Matriarch Reactors and Craft Aphelion
Larry
#1 Сообщение Larry »
Farm Matriarch Reactors in ARC Raiders to craft the Aphelion burst battle rifle—break leg plates, grab cores, extract safe, then build at a Level 3 Gunsmith with accelerators and complex parts.
You know that moment in ARC Raiders when your trusty rifle stops feeling trusty. You dump a whole mag, the target barely reacts, and suddenly every fight takes twice as long. That's when the Matriarch Reactor starts sounding less like "nice loot" and more like a plan. I've even seen people patch up their kits by grabbing credits or hard-to-find parts from places like EZNPC so they can keep runs going while they hunt the reactor for real.
Finding the Matriarch Without Wasting a Run
The Matriarch isn't always waiting for you. Most of the time you'll catch it when event flags kick off on maps like Dam Battlegrounds or Spaceport, and the lobby shifts from "loot quietly" to "everybody's sprinting toward noise." You'll spot the signs fast: heavy footsteps, big silhouettes, and way too much crossfire. If you're going in light, don't play hero. Bring ammo, bring heals, and bring a plan for getting out, because the reactor is only half the job.
The Leg-Plate Trick People Don't Talk About Enough
A lot of newer squads think the only way to get paid is to fully delete the boss. That's not how many teams do it. The safer approach is focusing fire on the leg armor plates. Keep your angles tight, burst when it turns, and don't get greedy when it stomps. Once those plates pop, the core's exposed and you can snag a reactor during the mess. It feels wrong the first time, like you're stealing it mid-fight, but it works. Just remember: the longer you hang around, the more likely another squad rolls up and third-parties you.
Extraction Is the Real Boss Fight
That reactor weighs 10kg, and you feel every bit of it. Movement gets sluggish, turns get wider, and you start making the kind of mistakes you don't usually make. People will chase you because you're basically advertising value. Some players panic and sell it since the coin price looks decent, but that's short-term thinking. If you want the Aphelion, you've gotta commit. Rotate early, avoid obvious lanes, and don't be afraid to stash the reactor in a safer spot if the map's too hot.
Building the Aphelion and Making It Count
Once you're back home, the checklist matters: Level 3 Gunsmith, then the craft using 1 Matriarch Reactor, 3 Magnetic Accelerators, and 3 Complex Gun Parts. The accelerators and parts tend to pile up if you've been farming elites, so the reactor is usually the choke point. The blueprint can drop off the Matriarch too, and it's been kinder since the 1.3 patch, so you're not stuck praying for weeks. And yeah, the Aphelion changes fights: two-round burst, energy punch, and it bites through shields that shrug off regular rounds. If you'd rather skip the grind some days and keep your schedule sane, a lot of players look at ARC Raiders Boosting to speed up the parts that feel like pure busywork.
