EZNPC What I Do to Max Caps Fast in Fallout 76
Larry
#1 Сообщение Larry »
Make caps fast in Fallout 76 with Cap Collector + Hard Bargain, a West Tek loot loop, quick vendor resets, and a CAMP water farm or player shop to keep income rolling daily.
Running out of caps in Appalachia always hits at the worst time. You spot a player vending the one plan you've been chasing, or a public event pops and you're one fast travel short. If you're fed up with counting pennies, treat caps like a routine, not a miracle. Some folks top up by trading smart, and others even look at places like EZNPC when they want game currency or specific items without spending all night grinding, but either way the goal is the same: stop feeling broke every session.
Perks That Pay You Back
Before you sprint into another farm run, check your cards. Cap Collector isn't flashy, but it quietly prints money over time, especially if your Luck isn't sitting in the gutter. Then there's Hard Bargain, which you should treat like a seatbelt: put it on before you talk to any robot vendor, every single time. You'll notice it right away when you dump weapons, chems, and random junk you don't need. A lot of players skip this and wonder why their "good haul" turns into pocket change.
A Route You Can Repeat Without Thinking
If you want consistent caps, you need a loop you can do half-asleep. West Tek is a classic for a reason. The Super Mutants come in tight groups, you're not hiking across empty hills, and the drops stack up fast. Clear the outside, then the interior, and loot like you mean it. Grab the rifles, scoop the ammo, take anything that'll sell. When you're crawling from weight, head to a station or Whitespring, cash out, then server hop if you're still in the mood. It's not glamorous, but it works.
Let Your CAMP Do The Boring Work
Caps feel easier when your CAMP is earning while you're off shooting things. A simple water setup with industrial purifiers turns into a steady pile of purified water you can sell on your next pass by a vendor. And if you've got vending machines, use them properly. Price stuff like a human being. Ammo that moves, plans people actually need, and legendaries that aren't trash. You're trying to get repeat buyers, not scare everyone away with wild numbers.
Daily Caps Limit And Keeping Momentum
The shared vendor cap pool is the real gate, so plan around it. Step 1: sell the heavy items first so your stash and carry weight stop fighting you. Step 2: once you drain the pool, quit forcing it; switch to player vending, run events, or stash the next batch for reset. Step 3: if you've got an alt, that's a clean way to keep farming without wasting value. After a week of doing this, caps stop being stressful, and you start making choices based on what's fun. If you want to speed that whole process up, some players pair their routine with Fallout 76 boosting for faster progress without burning out mid-grind.
