If you’re playing a Gladiator in Aion 2, the Expert’s Orichalcum Greatsword is one of the rare weapons you might want to consider. In this guide, I’ll explain what it is, how it works in practice, and some tips based on how most players approach this weapon. I’ll also touch on the in-game economy and crafting considerations.
What is the Expert’s Orichalcum Greatsword?
The Expert’s Orichalcum Greatsword is a Rare Greatsword type of weapon specifically for Gladiators in Aion 2. It’s not available to other classes, so if you are a Gladiator, this is one of the higher-tier weapons you might aim for at item level 38.
Here’s a quick look at the stats:
Attack: 166–224
Accuracy: 100
Critical Hit: 150
Block: 150
PvE Damage Boost: 5.00%
Manastone Slots: 2
From a practical standpoint, this weapon is designed for Gladiators who focus on heavy melee damage with some survivability thanks to the block stat. The PvE damage boost is modest but noticeable for general questing and dungeon content.
Most players will use this weapon in combination with high-defense armor, since its damage potential is strong but it’s primarily effective in sustained fights rather than quick skirmishes.
How Do You Get the Expert’s Orichalcum Greatsword?
Currently, the main way to obtain the Expert’s Orichalcum Greatsword is through crafting. At the moment, there are no detailed crafting recipes publicly available, so players usually wait for updates or guidance from more experienced crafters.
In general, crafting this type of rare weapon requires a combination of rare materials and some crafting skill levels. Most players check the in-game crafting interface regularly and coordinate with others to collect the needed resources. If you want this sword, it’s usually a good idea to start gathering materials early, as rare crafting items can take time to acquire.
How Useful is It in Practice?
In actual gameplay, the Expert’s Orichalcum Greatsword performs well for PvE content. Gladiators using this weapon typically:
Deal steady melee damage in dungeons.
Benefit from the 2 manastone slots, which can be used to further boost attack or survivability stats.
Take advantage of its block rating to reduce incoming damage in front-line combat.
Most players consider it a strong mid-level weapon. While it’s not the absolute top-tier endgame weapon, it is effective for players progressing through dungeons or world content around item level 38. It’s especially useful if you are farming or solo questing, as the damage range and critical hit stats allow for consistent output without relying heavily on buffs.
Can You Sell the Expert’s Orichalcum Greatsword?
Yes, the weapon can be sold to other players or through the in-game economy. Based on current market trends, it can fetch up to 5,710 gold. The exact price often varies depending on server economy and demand, but in general, rare Gladiator weapons maintain a high resale value.
Some players who focus on crafting and trading may also consider how to sell Aion 2 kinah safely on U4N, as in-game currency management is important when moving high-value items like this sword.
Tips for Gladiators Using This Weapon
Pair With Good Armor: Because the sword provides a balance between offense and defense, combining it with armor that boosts your survivability can make you a more consistent fighter in PvE scenarios.
Optimize Manastone Slots: Most players put offensive manastones in one slot and defensive ones in the other to balance damage and durability.
Practice Timing: Gladiators benefit from precise timing in their attacks, so make sure to learn your rotation with the Expert’s Orichalcum Greatsword. Even a high-damage weapon won’t help if your abilities are mis-timed.
Track Market Trends: If you plan to sell the weapon, keep an eye on the server economy. Prices can fluctuate, and coordinating with other players can help you get the best value.
Common Questions About the Weapon
Q: Is it worth crafting this weapon now?
A: In general, yes, if you are a Gladiator around level 38–40. It’s a strong weapon for mid-tier content and has good resale potential.
Q: Can other classes use it?
A: No. This weapon is exclusive to Gladiators. Other classes will need to focus on their own class-specific weapons.
Q: Are there upgrades available?
A: Yes, like other rare weapons, players usually socket manastones to improve specific stats. Most players experiment to find the best combination for their playstyle.
Q: How long will it stay useful?
A: Typically, weapons like this are most relevant for mid-level content. Top-tier endgame weapons may surpass it eventually, but for general questing and dungeons, it remains a solid choice.
The Expert’s Orichalcum Greatsword is a reliable Rare weapon for Gladiators in Aion 2. While it requires crafting to obtain, its stats make it a strong option for PvE content and mid-level gameplay. Most players will find it useful both in terms of performance and resale value. If you’re planning to progress with your Gladiator, this sword is worth considering.
By understanding its stats, potential manastone combinations, and resale possibilities, you can make the most of this weapon in everyday gameplay. And for those managing in-game currency, knowing how to sell Aion 2 kinah safely on U4N can ensure your investments remain secure.
Expert’s Orichalcum Greatsword in Aion 2: What You Need to Know
lonevessel
