Best Pitching Strategies for Quality Starts in MLB The Show 26
BlazeTiger
#1 Сообщение BlazeTiger »
In MLB The Show 26, earning a Quality Start (QS) is less about overpowering every hitter and more about controlling the flow of the game. A QS means pitching at least 6.0 innings while allowing 3 or fewer earned runs, and achieving it consistently requires efficient pitching, smart sequencing, and strong control of mechanics. In MLB The Show 26, the difference between a short outing and a deep start often comes down to small, repeatable habits rather than highlight plays.
1. Optimize Your Pitching Settings and Mechanics
The first step to consistent quality starts is setting up your controls for precision rather than convenience.
Pinpoint Pitching remains the most effective interface for serious pitching. It gives you the smallest accuracy window and allows full control over pitch location. When executed cleanly, it significantly reduces "missed spots" that lead to home runs or walks.
Turning on Fixed Pitch Location is another important adjustment. Once you select your target, the aim point stays locked, meaning you are no longer fighting small analog drift during windup. This helps you stay consistent over long innings, especially in tense situations with runners on base.
For camera settings, Strike Zone or Strike Zone 2 is the most practical choice. Seeing the plate head-on from the batter's perspective makes it easier to read swing timing, confirm pitch location, and adjust quickly between at-bats.
2. Master Pitch Tunneling and Sequencing
Quality starts are usually decided by how well you prevent hitters from timing you.
Pitch tunneling is one of the most effective tools available. The idea is to make different pitches look identical out of the hand before breaking in different directions. For example, a four-seam fastball up in the zone can be followed by a cutter or sinker that starts on the same path but moves late. This creates hesitation and weak contact instead of clean swings.
Speed variation is equally important. Alternating between fastballs and off-speed pitches like changeups or sliders disrupts timing more than raw velocity alone. Even good players struggle when their internal timing rhythm is constantly reset.
Avoid predictable patterns. Repeating the same opening pitch or always starting at-bats with a fastball makes you easy to read, both for AI and online opponents. If a hitter clearly misses a pitch, it can be effective to repeat it once before changing direction, as long as you don't turn it into a habit.
3. Pitch Location Strategy for Efficiency
To reach six innings consistently, you need to reduce pitch count by generating weak contact instead of chasing strikeouts every at-bat.
A simple location framework helps maintain efficiency:
Four-seam fastball: High and tight or inside corners to jam hitters and induce late swings
Sinkers or two-seam fastballs: Low in the zone or inside to generate ground balls and double plays
Cutter: On the outer edge to break bats and produce weak opposite-field contact
Changeup or splitter: Below the zone to force early swings and rollover grounders
Slider or sweeper: Low and away, especially effective in same-handed matchups when ahead in the count
The goal is not dominance through strikeouts, but controlled contact that keeps pitch counts low and innings long.
4. Stamina, Confidence, and In-Game Management
Even good pitching plans fall apart if you ignore stamina and confidence systems.
Each pitch type has its own command stability. If you repeatedly miss with one pitch, its accuracy degrades and it becomes more likely to hang. When this happens, shift temporarily to your more reliable pitches like the fastball or sinker to stabilize your rhythm.
Mound visits are also important. If you give up consecutive hits and notice confidence dropping, calling a mound visit can reset momentum. It helps prevent innings from spiraling into big run losses, which is often what ruins a potential quality start.
Finally, pay attention to the stretch delivery. With runners on base, your pitching motion speeds up and your input timing becomes tighter. Adjusting to this rhythm quickly is essential, because rushed inputs are a common cause of missed locations in high-pressure innings.
Achieving a Quality Start in MLB The Show 26 is about consistency, not perfection. When you combine precise settings, disciplined pitch sequencing, and smart in-game adjustments, you naturally extend outings and limit damage.
The most successful pitchers in the game are not the ones who throw the hardest, but the ones who waste the fewest pitches.
