If you have spent any real time pushing the endgame in Sanctuary, you already know that gold is the ultimate bottleneck. Between rerolling masterworking stats, imprinting high-tier aspects, and resetting paragon boards, your stash drains faster than a health globe in a Tier 100 Nightmare Dungeon. While many players default to Lightning Sorcerers or Whirlwind Barbarians for fast farming, a properly tuned Minion Necromancer is actually one of the most reliable, low-effort machines for accumulating Diablo 4 Gold.
Having tested dozens of setups across multiple seasons, I have found that the secret to a dedicated gold-farming Necromancer lies in balancing pure speed with effortless area-of-effect damage. Here is how to construct a build that melts packs, vacuums up loot, and keeps your pockets full.
Core Skills and Mechanics
For high-efficiency farming, you want a build that clears whole screens without forcing you to stop moving.
Raise Skeleton & Golem: Maximize your Skeletal Mages (Shadow) and Skeletal Warriors (Reapers). Reapers create corpses, while Shadow Mages deal massive passive DPS.
Decrepify: A crucial curse that slows enemies, reduces their damage, and provers cooldown reduction via Abhorrent Decrepify.
Corpse Explosion (Blighted): Your primary passive screen-wiper. Stack corpse generation so you can sprint through dungeons while an army of darkness cleans up behind you.
Blood Mist: Your unstoppable button. Use it to break crowd control and zip through elite packs safely.
Gear and Stat Priorities
To maximize your Diablo 4 Gold per hour, prioritize Movement Speed on both your Boots and Amulet. The faster you run between elite packs, the higher your yield. Pair this with Minion Attack Speed and Cooldown Reduction to keep your corpse engine running constantly. Look for Aspects like Unyielding Phalanges for minion survivability and Aspect of the Void to pull enemies together for fast clearing.
Farming Strategy
Focus your efforts on Whispering Tree dungeons and Helltide events. Helltide chests drop substantial quantities of raw gold, while completing Tree of Whispers bounties gives massive gold caches. If you want to bypass the repetitive grind altogether, some players choose to Buy Diablo 4 Gold from trusted platforms like EZBUFF to jump straight into high-end crafting and trade markets. However, if you prefer earning every coin yourself, keeping this Necromancer setup active will ensure you never run dry.
Focus on density, keep moving, and let your minions do the heavy lifting while you collect the rewards.
EZBUFF: How to Set Up a Necromancer Build Dedicated to Gathering Diablo 4 Gold
SilentTitan
