ARC Raiders: Stable Stock II Blueprint Farming Guide & Locations
Добавлено: 15 июн 2026, 05:54
The Stable Stock II Blueprint is an Uncommon weapon modification recipe in ARC Raiders. Finding and learning it permanently unlocks the ability to build the Stable Stock II attachment at your hideout, providing a substantial boost to mid-tier weapon handling.
Whether you are looking to optimize your extraction runs or trying to complete specific trader requests, understanding the exact drops, math, and logistics behind this blueprint will drastically cut down your grind.
Mod Statistics & Compatibility
Once the blueprint is learned and the attachment is crafted, it offers clean, horizontal recoil mitigation and fast weapon-tightening metrics. The attachment itself weighs 0.5 kg, while the physical blueprint schematic carries a weight of 0 kg in your extraction pack.
Stat Effects: Reduces both Dispersion Recovery Time and Recoil Recovery Time by exactly 35%. This allows you to reset your weapon crosshairs to dead-center significantly faster during sustained or burst firing.
Weapon Compatibility: The stock can be fitted directly onto five specific mid-to-late game firearms: the Arpeggio, Ferro, Renegade, Il Toro, and Stitcher.
Economy: If you happen to extract with a duplicate copy of the blueprint, it occupies a single inventory slot (Stack Size: 1) and can be sold to vendors in Speranza for a base value of 2,000 Coins. Note that some trading hubs and third-party listings value highly sought-after recipe duplicates at a higher premium depending on global economy supply.
How to Find the Blueprint
Like the vast majority of rare schematics in the game, the Stable Stock II Blueprint does not feature a single, fixed 100% spawn point. Instead, it relies on regional container tables.
1. Target Specific Containers
Your absolute highest statistical drop percentages come from Residential Containers Group and general Weapon Crates. When looting inside structures, focus heavily on searching:
Residential Desk Drawers and Wooden Drawers
Residential Closets and Chiffonier Drawers
White Office Drawers and Under-Desk Storage
2. Focus on High-Density Maps
To maximize your efficiency, target areas known for high residential and industrial density. Run the Dam Battlegrounds, specifically focusing on checking every container at the South Swamp Outpost. Alternatively, run the Buried City and drop straight into the Raider Camp situated directly beneath the Parking Garage, which guarantees two high-tier industrial containers with elevated pool tables.
3. Modifiers (Night Raids & Breach Zones)
To actively manipulate the drop rates in your favor:
Night Raids: Deploying during night cycles introduces tougher patrol variants but scales up the drop coefficient for Uncommon and Rare tier blueprints across all standard containers.
Breach Rooms: Saving your breach charges for security doors ensures access to restricted weapon caches. These isolated rooms bypass standard low-tier junk pools, giving you a much higher probability of pulling weapon mods.
Crafting Requirements and Economics
Once you successfully extract with the blueprint, navigate to your inventory in Speranza and select "Learn and Consume". This permanently saves the recipe to your Gunsmith Workstation (Level 2).
To craft a single functional Stable Stock II attachment, you must supply the following raw materials:
Required Crafting Material Quantity Needed Salvage / Recycle Yield
Mechanical Components 2x Yields 1x back upon salvage
Duct Tape 3x Yields 1x back upon salvage
Raider Coins (Crafting Fee) 2,000 Loses 1,060 Coins net on a rebuild
If you ever find yourself short on these components or prefer to skip the RNG entirely to acquire top-tier tactical setups, platforms like U4N allow players to safely trade for various arc raiders items, rare blueprints, and high-tier gear to optimize their loadouts instantly.
If you choose to dismantle or recycle the constructed stock later, the system returns 1x Mechanical Component and 1x Duct Tape, liquidating the remaining value for a net loss of 1,360 Coins from your baseline production costs. Because of this steep tax, it is always recommended to keep your crafted stocks assigned to active weapon platforms rather than melting them down.
Alternative Acquisition Paths
If your extraction runs are plagued by poor container RNG, you can pick up the completed attachment directly through specific traders inside Speranza:
Tian Wen: Sells completed versions of the stock for 6,000 Coins (Requires specific trader level unlocks, limited to a stock of 2 per daily rotation).
Shani: Offers occasional stock trades for 100x credits depending on your seasonal alignment level.
Quest Rewards: Completing the "What We Left Behind" questline issued by Tian Wen grants 1x fully built Stable Stock II as a fixed completion reward, allowing you to bypass the initial Gunsmith benchmark entirely while you hunt for the permanent blueprint.
