If you've been playing Roblox Grow a Garden 2 lately, you’ve probably seen players running around with a flashing, rainbow-colored tool and instantly maxing out their crops. That legendary tool is the Super Watering Can, and it is easily one of the best items in the entire game right now.
Getting your hands on it requires a mix of serious cash and a bit of real-world patience. Here is a straightforward breakdown of how to find, buy, and use the Super Watering Can, along with a couple of tips on how to save up the cash for it.
How to Locate and Buy the Super Watering Can
The Super Watering Can isn't something you can unlock through a quest or random drop—you have to buy it. It costs exactly 1,000,000 Shekels. Because it's an incredibly rare item, you can't just stroll into the shop and grab it whenever you want.
Here is exactly how the buying process works:
Find the Gear Vendor: Head over to the central hub area of the map. Look for the Gear Stall, which sits right next to the Seed and Sell vendors. The NPC running the stall is named George.
Watch the Restock Timer: George doesn't keep the Super Watering Can in stock all the time. His inventory rotates every 5 minutes. Keep an eye on the countdown timer displayed at the top of your screen. If you check his shop and the rainbow can isn't there, you have two choices: sit tight and wait for the next 5-minute refresh, or "server-hop" (leave the game and join a different server) to see if another George has it in stock.
Buy It Instantly: Because of how rare it is, you want to make sure you actually have your 1,000,000 Shekels ready to go before you start hunting for it. When it finally shows up in George's inventory, buy it immediately.
How to Equip and Use It
Once you’ve spent that massive pile of cash, you'll need to pull it out of your inventory to start using it:
Equip it: Open up your backpack by clicking the button in the upper-left corner of your screen. Flip over to the Gear tab, find the Super Watering Can, and select it.
What it does: Regular watering cans in the game are mostly used for small speed boosts or reversing crop decay, but the Super Watering Can is completely broken in the best way possible. When you use it, it creates a massive rainbow area-of-effect (AoE) on the ground. Any plant caught inside that rainbow circle instantly matures to full growth.
Quick Tips to Earn 1,000,000 Shekels Fast
Dropping a million Shekels on a single item is no joke, especially if you're relatively new to the game. If you want to fast-track your savings, try these two strategies:
Spam Bamboo Seeds: If you are still in the early-to-mid game, put your money into bamboo seeds. Bamboo is incredibly cheap to buy and grows ridiculously fast. It’s one of the most efficient loops for turning a small investment into quick, reliable profit.
Stack Your Sprinklers: Once you can afford high-tier sprinklers, place a bunch of them close together. The growth speed and plant-size bonuses from sprinklers actually stack up. By overlapping their ranges, your crops will balloon into giant versions of themselves almost instantly, allowing you to harvest them for millions of Shekels in no time.
How to Get Super Watering Can in Grow A Garden 2 Guide
FrostRogue7
- Начинающий
